  • Chris Clarke 22 posts 43 karma points
    Nov 27, 2010 @ 06:50
    Chris Clarke
    Package Uninstalled, Logs Tabs Remain
    I recently installed the CWS package for a look-see and uninstalled it.
    Now when I come into the Umbraco Content manager at the top 'Content' node there are 2 tabs;
    1. Contact Logs
    2. Email a Friend Logs
    Each tab contains a 'Could not load control : '/........./ContactForm_logs.ascx' message and explanatory text.
    How do I get rid of these tabs & references to .ascx files ?
  • Warren Buckley 2106 posts 4836 karma points MVP 7x admin c-trib
    Nov 27, 2010 @ 13:57
    Warren Buckley
    Hello Chris,
    Unfortunately as the CWS website package is quite an in-depth package, due to the number of files, content nodes, document types, macros etc that gets installed, unfortunately the uninstall process does not complete well.
    However to remove the two dashboard tabs, you need to modify the XML config file /config/dashboard.config and either delete the references or comment it out whatever you prefer.
    Hope this helps.
    Warren :)
    Nov 27, 2010 @ 19:39
    Chris Clarke
    Thanks, back to mormal now.
