I have a clean install of Umbraco 4.7.1.1. I have tried to install CWS v.3.01. I am able to install the package successfully without any errors. However, when I try to view the site I get the following errors.
This is the error that i get when I try to run a clean WebApplication project from Visual Studio 2010.
Made a little progress. Mysite is inside wwwroot/site. For some reason, some, but not all files, including all the macroscript files installted under wwwroot/site/site. I copied the folder and merged it with the parent directory (wwwroot/site) and the errors went away. The CSS still doesn't load though. Most likely references root in the files.
Anyways, something for you to check Bradley. Hope that helps.
Having the same issue here. Every single page that was installed by CWS shows these "Error loading MacroEngine script" errors on the page. I've now spent over 4 hours trying to get Umbraco to "work". When do I actually get to start building a website?
I am getting the same problem. It would be good to get some feedback on this. Also, I have gone through the tutorial of CWS on the tv videos but I have differences from the end result of the macro lesson. Hence, the need to get the CWS package correctly working.
Is there anything we can do in the meantime? I have spent several hours now trying to get Umbraco to run, and CWS seemed like the answer. Is it possible to change the version of Umbraco or CWS that we're using?
The package CWS 3.0.2 is compatible with Umbraco 4.7.1, 4.7.1.1 and 4.7.2. If you really need to get it to work asap, then I suggest you to use one of these umbraco versions.
Could you help me identify this problem? Not sure if it's related, but I'm getting the same message at the top and bottom of every page. All CSS appears to be missing. Using Umbraco 4.9.0 and CWS 3.0.1.
I'm afraid the CdLoader won't work for the Umbraco version 4.9. You can fix this by editing your CWS_Master.master and replacing <umbraco:Macro Alias="CWS_CdLoader" CssPaths="Reset.css|Styles.css|Search.css|ie.css|ie6.css" IncludeDefaultPaths="true" runat="server" /> with:
Also replace the <umbraco:Macro Alias="CWS_CdLoader" JsPaths="jquery.validate.js|jquery.validate.unobtrusive.js|script.js" IncludeDefaultPaths="true" runat="server" /> at the bottom of the page with:
That did remove the CdLoader error, but I am getting errors for all the rest of the <umbraco> macros in the master page now. (probably before too, just didn't notice it). The CSS and JS are now linked correctly in the page head and body, but aren't formatting the document (They aren't being pulled down from the network). Are the macros not supported at all in 4.9.0?
Still getting a handle on how Umbraco works unfortunately. CWS was suggested as a learning tool.
Fresh install of CWS
Error loading Razor Script CdLoader.cshtml
Method not found: 'Void System.Web.WebPages.WebPageBase.ExecutePageHierarchy(System.Web.WebPages.WebPageContext, System.IO.TextWriter)
or this is the error I get when I try run it from a clean Umbraco Installation and setup of site through IIS7
Error loading MacroEngine script (file: EmailAFriendLink.cshtml) Error loading MacroEngine script (file: SearchBox.cshtml)
So, apparently something to do with Razor / macros and the engines that run them but I can't figure out what.
Any ideas would be most useful.
Regards
Bradley
Having the same issue with a fresh install of umbraco and CWS from this morning.
Hi Jake
Thanks for the ideas, I will have a look into that and post back....
Bradley
Error loading MacroEngine script (file: CdLoader.cshtml)
Error loading MacroEngine script (file: Navi.cshtml)
Error loading MacroEngine script (file: NewsEventsSubNavi.cshtml)
Regards.
Hi everyone,
There have been certain changes in Umbraco 4.8 such as the ClientDependency library which makes the current package 3.0.2 incompatible with it.
Hope to have some time to fix this issues soon.
J
Thanks Jorge!
Hi Kurt,
Hope this helps,
J
Thanks Jorge,
