I just installed the version 3.01 of the CWS, into a new 4.9 Umbraco installation, then the razor files would not load, as weel as the media section seemed to be 'broken'.
Now when I try to uninstall the package, it doesn't let me, jus shows me a .net screen of death error.
I'm afraid the version 3.01 is only compatible with Umbraco 4.7.x. If you want to turn time back, simply uninstall the package and it should remove the document types, content, libraries and files from the Umbraco installation.
Help uninstalling CWS
How to turn time back in here?
Hi Antonio,
J
Hi Jorge
Yes I didn´t read the info in time, my fault, well it doesn't let me uninstall it either.
Luckily I am just starting a clean site so I won´t loose much if I start again from scratch.
Otherwise i copied all your razor love for inspiration, thanks much for that.
