  • Hywel Lewis 37 posts 138 karma points
    Mar 26, 2010 @ 21:46
    Hywel Lewis
    Contact Form Error
    Hi have juse setup a live version of the CWS on my new host which uses Plesk, but for some reason im getting errors on the email a friend and contact form, i have tired with SSL checked and un checked.
    when un checked i get this error
    The SMTP server requires a secure connection or the client was not authenticated. The server response was: SMTP authentication is required.
    and when checked i get this error
    Server does not support secure connections.
    My previous host used plesk and the form worked fine with no errors, is there something i need setup on my hosting package?? or a fix for this issue
    Any advice or help would be appreciated
    Cheers
    Mar 26, 2010 @ 23:16
    Hywel Lewis
    Problem solved,
     needed to add user details to the webconfig file, ooops :)
  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Mar 27, 2010 @ 10:43
    Warren Buckley
    No problem Hywel. I am glad you fixed it. Yes it is maybe not clear when you install it, but it is outlined in the documentation PDF.
    Warren
