    Nov 12, 2014 @ 12:05
    Ismail Mayat
    Domestic violence charity
    Kevin,
    I am thinking of using the starker kit with azure instance for a local domestic violence charity, will the kit work with azure? Initially i will be using free version so it will be sql ce I guess.  The other question its not local gov but it is service oriented so i could take bits i dont need, any comments suggestions most welcome.
    Regards
    Ismail
  • Kevin Jump 2348 posts 14896 karma points MVP 8x c-trib
    Nov 12, 2014 @ 12:54
    Kevin Jump
    Yes it works fine on azure (although I have seen issues on UaaS - but i don't have access so only been told they exist :) ).
    the localgovness of it is very light, its more just a service orienated thing, it's built around the idea of gateway/landing pages as the core navigation, the maps are just a version of the gMaps package, and the opening times, are similar.
    I've been thinking of making it a bit more generic for v7.2 so it would be cool to get any feedback you have.
    Kevin
    Nov 12, 2014 @ 16:22
    Ismail Mayat
    Kevin,
    Awesome, also i guess ideally you should install it in blank umbraco instance? I have created azure instance and for some reason its installed one of the starterkits.
    Regards
    Ismail
    Nov 12, 2014 @ 17:19
    Kevin Jump
    I think it works on top of a installed starter kit, but it's probably better if the site is completely blank : )
