Apologies for the delay in replying - I was just about to dash out the door!
It looks like a problem with the media picker - Could not load types from assembly uComponents.DataTypes, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null, errors:
Exception: System.TypeLoadException: Could not load type 'umbraco.editorControls.mediapicker.MemberPickerDataType' from assembly 'umbraco.editorControls, Version=1.0.5462.37523, Culture=neutral, PublicKeyToken=null'.
Could not load types from assembly uComponents.Legacy, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null, errors:
Exception: System.IO.FileNotFoundException: Could not load file or assembly 'uComponents.DataTypes, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
File name: 'uComponents.DataTypes, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null'
so that's a step forward I hope.
I'm not sure what code needs changing now, did a text search for it but nothing flagged up as obvious - to me anyway
It did run but I got - The view '/umbraco/install/views/index.cshtml' or its master was not found or no view engine supports the searched locations. The following locations were searched:
Double check that all of the /Umbraco core files have been copied across for the upgrade. The file at "/umbraco/install/views/index.cshtml" should definitely be there (for v7).
I get the picture of the people waving but no message and it doesn't look like it's installing - I can't see nuget on the server (that's Visual Studio anyway isn't it?) so do I use Microsoft Web Platform installer at this point?
Does anyone know if there is a version of (or fix for) uComponents that is compatible with Umbraco7?
Or, do I need to update my custom data types to use something else besides uComponents? I hope this isn't the case. If I do, can anyone recomment a procedure to properly/safely do this?
I did mistake of updating ucomponents on Umbraco 7.x version, my umbraco project failed to openup anything, I have just went into the bin folder of umbraco project and deleted all ucomponent*.dll files, and now this have resolved my issue.
Migrating an instance of LocalGov on Umbraco v6 to v7
Hi Kevin
is it possible to move an existing LocalGov instance running on Umbraco 6 to Umbraco 7?
I'm getting an error because of the uComponents
thanks
Steve
Hi Steve,
What's the error you're getting with uComponents?
- Lee
It looks like a problem with the media picker - Could not load types from assembly uComponents.DataTypes, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null, errors: Exception: System.TypeLoadException: Could not load type 'umbraco.editorControls.mediapicker.MemberPickerDataType' from assembly 'umbraco.editorControls, Version=1.0.5462.37523, Culture=neutral, PublicKeyToken=null'.
Hi Steve,
You should be able to delete the
uComponents.DataTypes.dllfrom your /bin folder. (The v4/v6 style data-types can't be used on v7 anyway).Cheers,
- Lee
Hi Lee
now I'm getting -
Could not load types from assembly uComponents.Legacy, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null, errors: Exception: System.IO.FileNotFoundException: Could not load file or assembly 'uComponents.DataTypes, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified. File name: 'uComponents.DataTypes, Version=5.5.0.0, Culture=neutral, PublicKeyToken=null'so that's a step forward I hope.
Ah ok, delete the
uComponents.Legacy.dlltoo. (It just contains a bunch of old/legacy data-types, which don't work in v7 either).Hopefully that should be all that need deleting.
Getting there
Invalid column name 'propertyEditorAlias'.Hmmm... is there anything more with the error? Bit difficult to figure it out.
- Lee
I think I need to run the install but of course you don't get the /install with 7.2.1 so I'm a bit stuck
do I need to run web platform installer or run an older installer 7.1?
To kick off the installer again, try setting the value of the
umbracoConfigurationStatusappSetting (in your Web.config file) to empty:It did run but I got - The view '/umbraco/install/views/index.cshtml' or its master was not found or no view engine supports the searched locations. The following locations were searched: /umbraco/install/views/index.cshtml
That folder was missing so I've just copied it over
Hi Steve,
To be honest, I'm not sure why the installer isn't working for you. Part of me thinks that maybe some other files/folders are missing?
You shouldn't need MS Web Platform Installer for doing this part.
- Lee
Many thanks in advance!!!
