How did you enter the coordinates in the backoffice? Could you show a screendump of that as well? Also have you tried checking the browser console to see if an error is displayed there?
I suspect the coordinates need to have a dot in them...so the coordinate for latitude would be 53.4405005 and the longitude would be -29.667901799999936 unless there is a script taking care of it as part of the package.
Ok, it's just a reference to a .css file that is missing. Nothing that would cause the original issue. I was thinking if there was a javascript related error somehow.
I'm afraid I don't have any other ideas about what to check etc. - But I think the coordinates look a bit weird as I mentioned before - But I assume the map is generated by the package and not something you generate yourself using Razor and JS for instance?
Problem with google map
Hi.
in the frontend the google map does not appear correctly (Umbraco version 7.1.9).
Can you help me?
thank you
html:
Hi Desiree
Hi Desiree
Hi Jan
this is the screendump:
thanks
Hi Desiree
Ok, so the coordinates are automatically picked based on the location you pick on the map. So that looks to be fine at a first glance.
So could you try and check the console log in the browser to see if you get an error message?
I have this error:
NetworkError: 404 Not Found - .../css/residents.css"
Hi Desiree
Hi Jan.
Yes, the map is generated by the package.
I try to uninstall and then reinstall the package.
Thank you.
