  • david 1 post 81 karma points
    Oct 27, 2015 @ 10:47
    david
    Login fails
    Dear Community,
    i´m new to Umbraco and to understand & learn the structure i installed the Local Gov Starter Kit. Seems to run but i´m not able to login the Backend with the provided username & passwd:
    KitAdmin jumoo
    Is this still the actual Login, i´m asking cause´the pdf manual is almost 2 years old.
    using Umbraco 7.3 without a starter kit & v5.1 Local Gov
    Thanks in advance
  • gary 385 posts 916 karma points
    Oct 27, 2015 @ 13:18
    gary
    Hi David
    If you installed Umbraco before you installed the starter kit, your username and password will be those you entered at the set up stage of Umbraco.
    Regards
    Gary
