Hello everyone!
We have created a new OSKI Starter Kit for Umbraco 9. If you have any questions, please write them in this branch, and we will try to help you.
Best regards,
OSKI Solutions
Please check input search. It is'nt mapping json response from API with js!
I check url demo: https://kit2022.oski.site/
Hello, we plan to publish fix this wee. i will message here.
Please check the updated version 1.0.1
Thanks, It working fine!!!
There are two questions:
1/ I see some problems on the site related to sitemap, all link error 500:
https://www.oski.site/sitemap
https://www.oski.site/xml-site-map
2/ OskiStarterKit does it run well on .net 6? I see error with (.NET 6 - VS 2022)
I using verion 1.0.1!
Can you check with 1.0.2 version?
Thank you very much!
Can you share the source with me?
How can I customize the current source according to my feature?
I'm needing it!
Hello. You can edit anything in razor templates. Unfortunately, we didn't decide if we a ready to publish this free with any open-source license. I will message on this topic if we decide to publish source codes.
I think now we have net 6. version
We will check and apply update ASAP
OSKI Starter Kit for Umbraco 9 Issues
Hello everyone!
Best regards,
OSKI Solutions
I'm needing it!
