  • Adi 17 posts 36 karma points
    Jan 05, 2012 @ 18:06
    Adi
    Error loading Razor Script
    I installed ImageGen first and then your package. everything run ok. I got dependecy check green tick. When i start to browse the site i get the following error. The page loads partly...
    d:\Adi\websites\EA\App_Data\TEMP\Razor\inline-bb79a4aca88d0a950f3056b10f91e7ef.cshtml(3): error CS0103: The name 'Library' does not exist in the current context
  • Warren Buckley 2106 posts 4836 karma points MVP 7x admin c-trib
    Jan 05, 2012 @ 18:17
    Warren Buckley
    Hello Adi,
    What version of Umbraco are you running?
    You can fidn out by clicking the About button found top right when logged into the umbraco back office.
    This error is to do with the Razor implementation in Umbraco V4 and is most likely missing due to being installed into an older version of Umbraco.
    Warren
    Jan 06, 2012 @ 10:58
    Adi
    Hi Warren,
    umbraco v 4.7.0 (Assembly version: 1.0.4090.38017)
    Adi
    Jan 06, 2012 @ 11:44
    Warren Buckley
    Hello Adi,
    Due to improvements with Razor in 4.7.1 you will need to make sure you are using that version of Umbraco.
    So you will need to install a new version of Umbraco that is the latest version (4.7.1) and re-try installing this package.
    Any problems let me know.
    Many Thanks,
    Warren
    Jan 06, 2012 @ 12:59
    Adi
    Hi Warren
    I grabed a more recent stable build umbraco v 4.7.1 (Assembly version: 1.0.4281.20201) and everything works perfect now.
    Many thanks for your patience and helping beginners like me
    Adi
    Jan 06, 2012 @ 13:11
    Warren Buckley
    No problem Adi. I am glad to have helped you. Here at Umbraco we like to keep up the motto of the 'friendly CMS' as having one fo the most helpful and friendly communities who will be more than happy to help you.
    Warren
