  • Lee Allan 11 posts 31 karma points
    Jan 31, 2012 @ 15:38
    Lee Allan
    Installation
    I was just wondering how you install this package? I tried through the package installer but it says that as it wasn't created with nuGet it is invalid.
    Thanks.
  • Warren Buckley 2106 posts 4836 karma points MVP 8x admin c-trib
    Jan 31, 2012 @ 16:09
    Warren Buckley
    Hi have you tired to install this into a V5 install?
    Currently the package is for V4 only at the moment, however I have a working site that you can pull down from BitBucket.org and take a look at and learn from.
    https://bitbucket.org/warrenbuckley/estate-agents-starter-site
    Warren :)
    Jan 31, 2012 @ 17:23
    Lee Allan
    Thanks Warren,
    Yes I was installing to V5 (or trying to!)  I'll check out that link.
    Thanks again.
    Lee.
    Feb 03, 2012 @ 10:42
    Lee Allan
    I downloaded the latest version for V5 and when trying to run it I get the following message:
    The 'umbraco-default' cache profile is not defined. Please define it in the configuration file.
    Can you help?
    Lee.
    Feb 03, 2012 @ 10:47
    Warren Buckley
    Hi Lee,
    Is this when you have downloaded my example site or a fresh clean installtion of Umbraco V5?
    If it is to do with a clean install, I think your question may be better off in the dedicated V5 forum:
    http://our.umbraco.org/forum/core/umbraco-5-general-discussion
    But I can try to help you anyway. Sounds like something is missing from the web.config file in the root of the website.
    Where did you download the V5 files from?
    Warren
    Feb 03, 2012 @ 10:57
    Lee Allan
    Hi Warren,
    I downloaded from your bit bucket link above.  I clicked on the latest version link and clicked on get source.  I assume this is the latest code in here?
    I'm new to umbraco so could be getting it all wrong.
    Lee.
    Feb 03, 2012 @ 11:00
    Warren Buckley
    Ah ok sounds like there is an issue with my example starter kit code.
    But to download a fresh copy of Umbraco V5, I would recommend you download Umbraco from Codeplex here:
    http://umbraco.codeplex.com/
    In the meantime I will look into the problem you was having with my example starter site and see what the issue is
    Warren
    Feb 03, 2012 @ 11:03
    Lee Allan
    Ok thanks for yoru help Warren.
    Lee.
