I have downloaded the source from the bitbucket and I'm having problems getting the site to run. I get the error below when I go to loaclhost.
Could not load file or assembly 'BingMaps.Umbraco.PropertyEditor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. An attempt was made to load a program with an incorrect format.
Has anybody got any clues to why or even a guide on how to get this up and running?
Hi Thanks for the replies. I can install a virgin 5.1 site and get it going no problem. What I'm trying to do here is use Warrens examples to get myself up to speed.
I have just got the site to work by dropping the folder with the BingMaps assembly in it. Im guessing its not critical.
@Jay - I believe what I have downloaded is something that was created for V5
I haven't updated the project for a little while to use the latest version of Umbraco, so if you are copying in components from that project into a newer version of the Umbraco build I have in source control, is hence why you might be seeing problems.
The Bing Maps property editor allows you to pick a location for each estate for sale by using a friendly google map to store the latitude and longtitude and zoom level, rather than using a textstring box to manually type these in yourself.
I have the site working I deleted the bingmaps folder under packages for now. I will try adding this package in later. I am just trying to get the site to run with the folder "Umbraco.StarterSite.EstateAgent.Web" I haven't tried to migrate it to 5.1 which is what I'm interested in using for the membership users.
If I create a basic 5.1 site can I just copy across the folders onto this? If so which folders are specific to your application? Is there a way to migrate the database to 5.1 as I guess this has structural changes for 5.1?
The site seems to work ok however when I log into the backoffice I'm getting a few exceptions. For example clicking the home folder and clicking any property i.e. Stonehenge.
Its a good example to use so I'm keen to get it going so I can get up to speed with V5.
Best Regards
Brian
Back Office Exception details
ExceptionObject reference not set to an instance of an object.Stack traceat System.Object.GetType() at Umbraco.Cms.Web.Mapping.CmsModelMapper.<ConfigurePersistenceToModelMappings>b70(AttributeDefinition source, DocumentTypeProperty dest) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Mapping.CmsModelMapper.<ConfigurePersistenceToModelMappings>b6a(TypedAttribute x) at Umbraco.Framework.TypeMapping.MappingExecutionScope.<>cDisplayClass71.<CreateOnce>b__6() at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce(Object source, Type targetType, Func1 factory) at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce[TTarget](Object source, Func1 factory) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.EnumerableTypeMapper2.PerformMapping(TSource sourceSequence, TTarget targetSequence, MappingExecutionScope mappingExecutionScope) at Umbraco.Framework.TypeMapping.EnumerableTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Mapping.TypedEntityToContentProperties1.GetValue(TEntity source) at Umbraco.Framework.TypeMapping.MemberMappingExpression1.MapUsing[TMember](MemberMapper2 memberMapper) at Umbraco.Framework.TypeMapping.FluentMappingEngineContext2.MapFromRule(PropertyMapDefinition info, MemberExpressionSignature expression, Object& value) at Umbraco.Framework.TypeMapping.ObjectMapper2.Map(Object source, Object target, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Mapping.RevisionToContentEditorModel1.<.ctor>b0(Revision1 x) at Umbraco.Framework.TypeMapping.MappingExecutionScope.<>c__DisplayClass71.<CreateOnce>b6() at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce(Object source, Type targetType, Func1 factory) at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce[TTarget](Object source, Func1 factory) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Framework.TypeMapping.MappingExecutionScope.<>cDisplayClass71.<CreateOnce>b__6() at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce(Object source, Type targetType, Func1 factory) at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce[TTarget](Object source, Func1 factory) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map(Object source, Type sourceType, Type destinationType) at Umbraco.Framework.TypeMapping.AbstractMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Editors.AbstractRevisionalContentEditorController1.Edit(Nullable1 id) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName)
Setting Up the V5 site from bitbucket
Regards
Brian
Hi Brian, welcome aboard!
Any particular reason why you're installing from source code? There's plenty of binaries here:
http://umbraco.codeplex.com ;
You can also use Microsoft Web Platform Installer to get started
Hi Brian,
I believe this package is a v4.7 only one
HJay
*LOL* Whoops... I didn't see this was a project forum *hiding in shame* ;)
Brian
Hello Brian,
Yes you are right I have a V5 version of the starter site here on BitBucket
https://bitbucket.org/warrenbuckley/estate-agents-starter-site
You could try to install Bing Maps or the Google Maps property editor packages as both will work with the site code:
http://our.umbraco.org/projects/backoffice-extensions/google-maps
http://our.umbraco.org/projects/backoffice-extensions/bing-maps-property-editor
Any problems just shout.
Warren :)
Many thanks Warren.
Best Regards
Brian
ExceptionObject reference not set to an instance of an object.Stack traceat System.Object.GetType() at Umbraco.Cms.Web.Mapping.CmsModelMapper.<ConfigurePersistenceToModelMappings>b70(AttributeDefinition source, DocumentTypeProperty dest) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Mapping.CmsModelMapper.<ConfigurePersistenceToModelMappings>b6a(TypedAttribute x) at Umbraco.Framework.TypeMapping.MappingExecutionScope.<>cDisplayClass71.<CreateOnce>b__6() at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce(Object source, Type targetType, Func1 factory) at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce[TTarget](Object source, Func1 factory) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.EnumerableTypeMapper2.PerformMapping(TSource sourceSequence, TTarget targetSequence, MappingExecutionScope mappingExecutionScope) at Umbraco.Framework.TypeMapping.EnumerableTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Mapping.TypedEntityToContentProperties1.GetValue(TEntity source) at Umbraco.Framework.TypeMapping.MemberMappingExpression1.MapUsing[TMember](MemberMapper2 memberMapper) at Umbraco.Framework.TypeMapping.FluentMappingEngineContext2.MapFromRule(PropertyMapDefinition info, MemberExpressionSignature expression, Object& value) at Umbraco.Framework.TypeMapping.ObjectMapper2.Map(Object source, Object target, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Mapping.RevisionToContentEditorModel1.<.ctor>b0(Revision1 x) at Umbraco.Framework.TypeMapping.MappingExecutionScope.<>c__DisplayClass71.<CreateOnce>b6() at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce(Object source, Type targetType, Func1 factory) at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce[TTarget](Object source, Func1 factory) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Framework.TypeMapping.MappingExecutionScope.<>cDisplayClass71.<CreateOnce>b__6() at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce(Object source, Type targetType, Func1 factory) at Umbraco.Framework.TypeMapping.MappingExecutionScope.CreateOnce[TTarget](Object source, Func1 factory) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(TSource source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractTypeMapper2.Map(Object source, MappingExecutionScope scope) at Umbraco.Framework.TypeMapping.AbstractFluentMappingEngine.Map(Object source, Type sourceType, Type destinationType) at Umbraco.Framework.TypeMapping.AbstractMappingEngine.Map[TSource,TDestination](TSource source) at Umbraco.Cms.Web.Editors.AbstractRevisionalContentEditorController1.Edit(Nullable1 id) at lambda_method(Closure , ControllerBase , Object[] ) at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary2 parameters) at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClass15.<InvokeActionMethodWithFilters>b__12() at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func1 continuation) at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters) at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName)is working on a reply...
