  • Tommy 12 posts 75 karma points
    Feb 21, 2013 @ 21:41
    Tommy
    How to add panels ?
    It seems I can't add panels on a standard page... Isn't there supposed to be a way to select which panels I wan't to add to a page ?? See the attached screendump
    Feb 21, 2013 @ 21:45
    Tommy
    Seems it's the same problem if I wish to alter the navigation on the home page:
  • Chris Koiak 700 posts 2626 karma points
    Feb 21, 2013 @ 22:36
    Chris Koiak
    Although it shouldn't be required, installing uComponents should fix this.
    Feb 21, 2013 @ 22:47
    Tommy
    Thanx! I just installed Contour forms, which apparently fixed it too ;-)
