  • Shanti 2 posts 22 karma points
    Jun 27, 2013 @ 03:04
    Shanti
    Posting form without using source code
    I would like to know is there any workaround to create custom form, model and post the model(similar to Contact Form) without making any changes to source code. I heard usually packages will allow users to directly make changes in Umbraco rather than source code changes in project solution, so would like to check is there any way of doing this. If yes, please suggest me what I can do. Thank you so much for your time!
  • Chris Koiak 700 posts 2626 karma points
    Jun 27, 2013 @ 07:59
    Chris Koiak
    The best Umbraco form package is Contour,http://umbraco.com/products/more-add-ons/contour.aspx
    This package only has a fixed set of customisable fields.
    Jun 27, 2013 @ 10:13
    Rich Green
    Agree with Chris, that's the easiest route by far.
    If you wanted to go down the custom route then it's possible using nodes, I blogged around this topic here http://www.umbrellainc.co.uk/blog/umbraco-think-different/
    Rich
    Jun 27, 2013 @ 16:35
    Shanti
    Thank you guys for posting the helpful replies quickly. Appreciate it and I will take a look at those things
