hi im trying to install the package to a fresh 6.1.2 installation and altough package seems to install this error comes up:
Stack Trace:
usercontrols_StandardWebsiteInstall.Page_Load(Object sender, EventArgs e) +276
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +51
System.Web.UI.Control.OnLoad(EventArgs e) +92
System.Web.UI.Control.LoadRecursive() +54
System.Web.UI.Control.LoadRecursive() +145
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +772
i couldnt find any similar error on the forum and is my first time using umbraco any help would be greatly apreciated
if I turn on debug mode before I install I get the following detail in the error message:
Source Error:
Line 39: int slideShowId = -1;
Line 40:
Line 41: root.SetValue("primaryNavigation", root.Id + ""); Line 42: root.SetValue("headerNavigation", "");
Line 43: root.SetValue("slideshow", "");
I bet it has to do with the fact that the root is not published yet.
The code has a commented out line of code using documents rather than content on line 32. If line 32 was used instead of line 30 I reckon it would work.
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: CS1061: 'umbraco.cms.businesslogic.web.Document' does not contain a definition for 'SetValue' and no extension method 'SetValue' accepting a first argument of type 'umbraco.cms.businesslogic.web.Document' could be found (are you missing a using directive or an assembly reference?)
Source Error:
Line 40:
Excellent changing line 30 fixed it to perfection ty very much 4 your help sorry that i couldnt high 5 i dont have enough karma yet but as soon as i can i certainly will come back and do so...:)
error on installation
Stack Trace:
also i installed locally using webmatrix my database is in microsoft sql server 2012
ty 4 any help :)
jb santana
Source Error:
Line 39: int slideShowId = -1; Line 40: Line 41: root.SetValue("primaryNavigation", root.Id + ""); Line 42: root.SetValue("headerNavigation", ""); Line 43: root.SetValue("slideshow", "");Source File: c:\ewide.projects\tr\Standard Website Mvc\Standard Website Mvc\usercontrols\StandardWebsiteInstall.ascx.cs Line: 41
I'll give it a whirl, 2 tix
Compilation Error
Source Error:
So its a different error but now I need the old api stuff. :(
Hang on. Here is a fix. Update line 30 to be
var root = contentService.GetRootContent().Where(x => x.Name.StartsWith("Home")).FirstOrDefault();
ok ill try and verify ill keep u posted and ty..:)
