  • Daniel 29 posts 142 karma points
    Mar 19, 2021 @ 12:09
    Daniel
    Package not working on 8.12.1, but working on 8.11.2
    Hi iMazel team, First of all, a great thank you for your updated kit, it is full of great features.
    When trying to install on today's latest version - 8.12.1 - I got a successful package install, but when going to the content section, I got a 404 error message for '/umbraco/backoffice/api/dashboard/getpagesettings' not found.
    Tried 2 times, 2 times same error.
    I then tried installing on version 8.11.2, and that went successfully.
    Any clue why?
    Thanks!
  • Sotiris Filippidis 283 posts 1497 karma points
    Mar 19, 2021 @ 12:45
    Sotiris Filippidis
    Hi Daniel, and thank you for your kind words!
    We happened to set up uMazel on 8.12.1 a couple of days ago, and we faced no issues with this.
    The only thing I can think of is maybe you are missing the "umazel dashboard" node from the Settings subtree? This should have been created along with other nodes under Settings.
    Mar 20, 2021 @ 14:39
    Daniel
    Hi Sotiris, Thanks for the prompt reply.
    I tried again with v8.12.1, this time successfully :-)
    The difference with the previous 2 times was that now I used the package from the "Install" tab, rather than from the "Install Local" tab when selecting the package. I was not sure the package was the 2.0 version, so I downloaded the 2.0 version from OUR, and tried - unsuccessfully -to install it.
    So the package installed directly from the packages tab selecting uMazel works, the package downloaded from OUR does not.
    Daniel
    Mar 20, 2021 @ 14:47
    Sotiris Filippidis
    This sounds weird! We'll give it a go with both ways and see what we come up with. Thanks for the heads up!
