First of all, thank you for a great starter kit!
I've just set up a clean solution running .NET framework 4.7.2 and installed umbraco 8.12.0 and subsequently the Umazel Starter Kit 2.0.
After creating a Contact Section and adding the various configurations through the backoffice, I am unfortunately met with a series of issues.
(recaptcha sitekey is v3)
Validation is only working on the checkbox and I cant seem to opt out of, or configure any validation.
Also, I am met with the following console error:
Uncaught ReferenceError: Sys is not defined
Looking through the console, it looks as if the error is originating from here:
onclick="Sys.Mvc.AsyncForm.handleClick(this, new Sys.UI.DomEvent(event));" onsubmit="Sys.Mvc.AsyncForm.handleSubmit(this, new Sys.UI.DomEvent(event), { insertionMode: Sys.Mvc.InsertionMode.replace, httpMethod: 'POST', onFailure: Function.createDelegate(this, ShowContactError), onSuccess: Function.createDelegate(this, ShowContactSuccess) })
Does anyone have any idea of what's going on?
All the best!
I have added the following line to the Web.config, which seems to have taken care of "Uncaught ReferenceError: Sys is not defined"
<add key="UnobtrusiveJavaScriptEnabled" value="true" />
However I am still getting the same validation issues as before, as well as the following error
(index):252 Uncaught TypeError: $(...).valid is not a function at HTMLButtonElement.validate ((index):252)
Errors when using the Contact Section
All the best!
