First of all great package we have here! Congrats!
I used this package on umbraco 7 and there I was able to change the controller and send emails.
Now, on Umbraco 8 version I can't find that controller or any other way to send emails properly using contact form component. I just found a JS called contact-form.js is this the way?
I just have a blank page saying "{success = false}"
I already setup all the fields on the backoffice and just entered the smtp tags on web.config, but no luck.
Send Emails with Umazel
Hi there,
Can anyone help me on this?
Thank you.
Tiago Mendes
Hi there,
I just found the controller. Seems to be a DLL under MVC class.
I have this error when I try to send a Email:
What is the right way to fix this? Do I need to create another controller to workaround?
Thank you. Tiago Mendes
