  • Bilal Haidar 144 posts 410 karma points
    Dec 17, 2016 @ 11:26
    Bilal Haidar
    Documentation on how this template was built?
    Is there a documentation on how this template was built from the ground up?
  • Sotiris Filippidis 286 posts 1501 karma points
    Dec 17, 2016 @ 11:32
    Sotiris Filippidis
    No, but I find your suggestion very interesting. As far as I can understand, you're not asking for documentation in the strict sense of the word, but rather for a "how it was done" description - am I correct? Could you please elaborate?
    Dec 17, 2016 @ 12:18
    Bilal Haidar
    Hi Sotiris,
    Let me illustrate more. I am an experienced ASP.NET developer. Coming into the world of Umbraco is a bit different. Umbraco has its own concepts and mentality.
    The documentation I was hoping to find is to know how you thought about selecting your document Types, how you thought that better to add a set of properties so that Editors could use to changes content whenever they want, etc.
    Such hints and best practices would really help grow the community and make Umbraco more accessible.
    Regards Bilal
    Dec 19, 2016 @ 20:57
    Bilal Haidar
    After going through the starter kit, I can see it has a complicated structure behind it. I am sure it took you lots of efforts to come up with. Big thanks to you, ευχαριστώ :-)
    What's your recommendations or approach to understanding how the starter kit was built, the different document types used, etc.
    I appreciate your view on that.
    Regards Bilal
