  • Kevin Coster 83 posts 120 karma points
    Dec 23, 2016 @ 00:26
    Kevin Coster
    Umazel creating an Author
    Not sure if this is a core issue with umbraco or related to Umazel Starter kit... When creating an author within the blog options uploading image comes up with an error.
    /umbraco/backoffice/UmbracoApi/Media/PostAddFile
    After googling around i think its a general fault within Umbraco but im not sure. There is nothing in the log when the error takes place.
    I have two separate instances of Umazel and can replicate on both Umbraco version 7.5.3 assembly: 1.0.6092.24019
    any suggestions as I havent seen a fix for it otherwise.
    Dec 29, 2016 @ 12:02
    Dave Woestenborghs
    Hi Kevin,
    Does the media picker perhaps as a start node set which doesn't exist anymore in the media library ?
    Dave
  • Morten 20 posts 132 karma points
    Dec 30, 2016 @ 10:55
    Morten
    This part is working fine with me. enter image description here
  • Sotiris Filippidis 286 posts 1501 karma points
    Jan 13, 2017 @ 14:13
    Sotiris Filippidis
    I can also confirm that it's working properly. Maybe an Umbraco-related issue or an installation-specific issue?
