Using Vorto will probably do the job, but you'll have to do a lot of things.
I created this starter kit using the "separate content trees" approach for each language. That is, you can create multiple home pages and assign a different language to each one (and its whole tree). Those can be subdomains or just different paths e.g. mysite.com/en/somepath, mysite.com/de/somepath
Localization available
There's any way to localize the content?
I'm trying to use Vorto, but I'm a newbie, and your "complex" objects, are not simple as Umbraco default ones.
Thank you
Ok, thank you. I'll give it a shot.
Best regards.
PS: Great job by the way ;)
Thanks! All localizable literals are already in the Dictionary, so you can easily add translations for more languages.
