  • Lake guy 5 posts 83 karma points
    Feb 20, 2017 @ 18:53
    Lake guy
    Blog post date format
    First - thanks for the great starter kit. There's a bunch of functionality in here!
    I'm new to Umbraco. I don't know if this is an Umbraco question or a Umazel question. The date format on my blog is appearing in dd/mm/yyyy format, in spite of the US-en language specified in my user. I prefer mm/dd/yyyy. I see that DotSee.UmbracoExtensions.General specifies the dd/mm/yyyy format. Is there a recommended way to override this format? Or should it be inheriting from some global setting?
    Thanks, J
  • Sotiris Filippidis 286 posts 1501 karma points
    Feb 20, 2017 @ 19:54
    Sotiris Filippidis
    Hi and thanks for the kind words!
    Well, it's a bit of both depending on the context. For this starter kit and the case at hand, it's a Umazel question since there is a property on the blog root page that you can set to have the date format as you like.
    Feb 20, 2017 @ 20:26
    Lake guy
    Ah, I probably looked at that setting too. Hidden in plain sight.
    Thanks for your prompt reply!
    J
