Thank you for you nice package.
I have problem with the mobile-menu sometimes:
When I in the menu click on a subscreen I get 2 icons in the header.
The left one does nothing but the left one opens the menu as it should.
But when I try to click on the + sign to open the sublevel nothing happens.
Clicking on the top levels works OK.
Tomas, it looks like you tried to add a link but it's not going anywhere. If this was your intention, could you please edit your post so that the link works?
Sorry,
It should not be a link in the text. I only referred to the link in the example.
Everything is working OK exept from the problem I described.
Tomas
I can't reproduce it - I tested it both on Chrome (mobile view) and on my phone (Windows Phone - yes, I know :) ) and the third level appears to be rendering correctly. I used the Umazel demo site for this.
I also don't get 2 icons, only one on the right, as expected.
What browser / device are you using that presents this problem? Have you tested it on other browsers / devices?
2 mobile-menu-icons
Hi Thank you for you nice package. I have problem with the mobile-menu sometimes: When I in the menu click on a subscreen I get 2 icons in the header. The left one does nothing but the left one opens the menu as it should. But when I try to click on the + sign to open the sublevel nothing happens. Clicking on the top levels works OK.
In this example clicking on Registrera medlem causes this problem.
Anybody seen this problem before?
Tomas
Sorry, It should not be a link in the text. I only referred to the link in the example. Everything is working OK exept from the problem I described. Tomas
Yes I have tested it with Firefox, Chrome and IE. All with the sam result.
I,m running local on WebMatrix and IISexpress on Windows 10. Perhaps is that the problem?
