  • Simeon Ostberg 123 posts 389 karma points
    May 03, 2017 @ 15:24
    Simeon Ostberg
    Portfolio item not working
    Hello everyone,
    I just discovered a strange problem with the portfolio item:
    I have two language trees (German and English). When I add a portfolio section on any page (no matter which tree), the page loads up normally. As soon as I add a portfolio item on the page, different things happen:
    • On the German tree it takes unusually long to save the item (the system including the front end kind of hangs), but then the item is visible on the page and working.
    • On the English tree the item is saved regularly, but when I open the page, it displays an error message and the page doesn't load regularly.
    Is there any place, where I can look to solve this?
    Thanks a lot, Simeon
    May 04, 2017 @ 12:20
    Simeon Ostberg
    Hello everyone,
    a programmer found a possible source of the error:enter image description here
    He said, the problem is with counting items in the virtual nodes, but can't dive deeply into the structure.
    I would be happy, if someone would know, where to look for solving this error.
    May 05, 2017 @ 11:37
    Alex Skrypnyk
    Hi Simeon
    Can you share the code with us?
    Alex
    May 05, 2017 @ 13:39
    Simeon Ostberg
    Hi Alex,
    Which code do you mean? SectionPortfolio.cshtml?
    @inherits Umbraco.Web.Mvc.UmbracoViewPage<SectionPortfolio>
    @using DotSee.UmbracoExtensions;
    @using DotSee.Portfolio;
        SectionPortfolio currSection = Model;
        PortfolioHelper portfolioHelper = PortfolioHelperMaker.GetCachedPortfolioHelper(ApplicationContext, currSection);
        string containerTypeClass = (portfolioHelper.Masonry) ? "masonry" : "grid";
        string spacingClass = (portfolioHelper.Spacing) ? "spacing" : "";
        string itemClass = (portfolioHelper.Spacing) ? "container-" + containerTypeClass + " nf-col-" + portfolioHelper.NoOfCols : "row container-" + containerTypeClass + " nf-col-" + portfolioHelper.NoOfCols;
        string containerClass = (portfolioHelper.Wide) ? "container-fluid" : "container";
        int cropwidth = (portfolioHelper.Wide)
            ? (portfolioHelper.Spacing) ? 877 : 952
            : (portfolioHelper.Spacing)? 650: 600;
    <section id="section_@currSection.Id.ToString()" class="@currSection.GetSectionEffectCssClass() ptb-60 ptb-sm-60 text-center">
        <div class="@containerClass">
            <h3>@currSection.Name</h3>
            <div class="spacer-30"></div>
            @if (portfolioHelper.HasCategories)
            <div class="row">
                <ul class="container-filter categories-filter">
                    @if (!currSection.HideAllCategoryOption)
                        string allCatsLabel = currSection.AllOptionLabel;
                        if (currSection.ShowItemCount) {
                            allCatsLabel += string.Format(" ({0})", portfolioHelper.GetTotalCount().ToString());
                    <li><a class="categories active" data-filter="*">@allCatsLabel</a></li>
                    @foreach (DGenericCategoryItem c in portfolioHelper.GetCategories())
                        string filter = c.Id.ToString();
                        string name = c.Name;
                            name += string.Format(" ({0})", portfolioHelper.GetCountPerCategory(c).ToString());
                        <li><a class="categories" data-filter=".@filter">@name</a></li>
                </ul>
            <div class="@itemClass">
                @foreach (PagePortfolioItem item in portfolioHelper.GetPortfolioItems())
                    bool hideCategories = item.DoNotDisplayCategories;
                    bool hideDates = item.DoNotDisplayReleaseDate;
                    //Get the category names as a comma delimited list for display
                    string categoryNames = item.GetPortfolioCategoryNames();
                    //Get the ids and drop commas - those will be in the class attribute for script to work
                    string itemCategories = item.Categories;
                    string itemCategoriesNoCommas = itemCategories.Replace(" ", "").Replace(",", " ");
                    string imageThumb = "";
                    string imageFull = "";
                    //string imageTitle;
                    int counter = 0;
                    //TODO: Get image from media and image cropped correctly
                    IPublishedContent mediaItem = item.GetPortfolioListImage();
                    if (mediaItem == null)
                        imageThumb = "/img/noimage/gallery_noimage.png";
                    else
                        imageThumb = (currSection.Masonry) ? mediaItem.GetCropUrl(width: 800, imageCropMode: global::Umbraco.Web.Models.ImageCropMode.Max) : mediaItem.GetCropUrl(cropwidth, 350);
                    counter++;
                    <div class="nf-item @itemCategoriesNoCommas @spacingClass">
                        <div class="item-box">
                            <a href="@item.Url" title="@item.GetPageTitleForMenu()">
                                <img class="item-container" src="@imageThumb" alt="@counter" />
                                <div class="item-mask">
                                    <div class="item-caption">
                                        <h5 class="white">@item.GetPageTitleForMenu()</h5>
                                            <p class="white">
                    @Html.Raw(item.Summary)
                </p>
                                        @if (!currSection.DoNotDisplayCategories && !hideCategories)
                                            <p class="white">@categoryNames</p>
                            </a>
    </section>
    The Stack trace is:
    [IndexOutOfRangeException: Index was outside the bounds of the array.]
    DotSee.VirtualNodes.VirtualNodesUrlProvider.ConstructUrl(UmbracoContext umbracoContext, Int32 id, Uri current, UrlProviderMode mode, IPublishedContent content) +1125
       DotSee.VirtualNodes.VirtualNodesUrlProvider.GetUrl(UmbracoContext umbracoContext, Int32 id, Uri current, UrlProviderMode mode) +347
       Umbraco.Web.Routing.<>c__DisplayClass3.<GetUrl>b__0(IUrlProvider provider) +50
       System.Linq.WhereSelectArrayIterator`2.MoveNext() +82
       System.Linq.Enumerable.FirstOrDefault(IEnumerable`1 source, Func`2 predicate) +215
       Umbraco.Web.Routing.UrlProvider.GetUrl(Int32 id, Uri current, UrlProviderMode mode) +236
       Umbraco.Web.Models.PublishedContentBase.get_Url() +184
       ASP._Page_Views_Partials_SectionPortfolio_cshtml.Execute() in c:\StarBase\StarBase.Staging\Views\Partials\SectionPortfolio.cshtml:85
       System.Web.WebPages.WebPageBase.ExecutePageHierarchy() +280
       System.Web.Mvc.WebViewPage.ExecutePageHierarchy() +126
       System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +125
       Umbraco.Core.Profiling.ProfilingView.Render(ViewContext viewContext, TextWriter writer) +140
       System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model, ViewDataDictionary viewData) +147
       ASP._Page_Views_Partials_PageSectionRenderer_cshtml.Execute() in c:\StarBase\StarBase.Staging\Views\Partials\PageSectionRenderer.cshtml:48
       ASP._Page_Views_pageInner_cshtml.Execute() in c:\StarBase\StarBase.Staging\Views\pageInner.cshtml:23
       System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +110
       System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +380
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +109
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilterRecursive(IList`1 filters, Int32 filterIndex, ResultExecutingContext preContext, ControllerContext controllerContext, ActionResult actionResult) +890
       System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +97
       System.Web.Mvc.Async.<>c__DisplayClass21.<BeginInvokeAction>b__1e(IAsyncResult asyncResult) +241
       System.Web.Mvc.Controller.<BeginExecuteCore>b__1d(IAsyncResult asyncResult, ExecuteCoreState innerState) +29
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +111
       System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +53
       System.Web.Mvc.Async.WrappedAsyncVoid`1.CallEndDelegate(IAsyncResult asyncResult) +19
       System.Web.Mvc.MvcHandler.<BeginProcessRequest>b__5(IAsyncResult asyncResult, ProcessRequestState innerState) +51
       System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +606
       System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +288
    Simeon
    May 16, 2017 @ 09:50
    Simeon Ostberg
    Hi!
    Unfortunately I just realized, that the blog post item brings up the same error message and the same behaviour (working on German language tree, not working on English language tree):
    Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
    Line 51:                             }
    Line 52:
    Line 53:                             <span>@item.GetPostDate()</span></div>
    Line 54:
    Line 55:                             <div class="post-header">
    Source File: c:\Umbraco\Views\pageBlogList.cshtml Line: 53
    Stack Trace:
       ASP._Page_Views_pageBlogList_cshtml.Execute() in c:\Umbraco\Views\pageBlogList.cshtml:53
    I would be really grateful, if anyone had an idea...
    Thanks!
    Simeon
    May 17, 2017 @ 11:46
    Alex Skrypnyk
    Hi Simeon
    Can you show Source File: c:\Umbraco\Views\pageBlogList.cshtml Line: 53 ?
    May 21, 2017 @ 20:50
    Alex Skrypnyk
    Hi Simeon
    Did you solve this issue? can you share with the community?
    Alex
    May 23, 2017 @ 08:58
    Simeon Ostberg
    Hi Alex,
    Sorry, I didn't get your previous reply. No, the issue is still unsolved. The code of the line is:
    Thanks a lot!
    Simeon
    May 24, 2017 @ 08:53
    Alex Skrypnyk
    Hi Simeon
    Can you look at source code of 'GetPostDate' method?
    May 26, 2017 @ 07:50
    Simeon Ostberg
    Hi Alex,
    Please excuse my late reply! What do you mean with source code? Isn't the line I posted the source code?
    Or do you mean the code section after opening the page?
    Best, Simeon
    Nov 07, 2017 @ 14:51
    Simeon Ostberg
    Hi everyone,
    Now, much later I can at least post a possible solution for the portfolio item.
    I found this post: https://our.umbraco.org/projects/starter-kits/umazel-starter-kit-responsive-bootstrap-theme/umazel-starter-kit-general-discussion/87436-index-out-of-bounds-with-multi-lingual-setup#comment-277193
    And by taking out the line out of web.config
    <add key="virtualnode" value="folderArticlePosts,folderSections,folderPortfolioItems,sectionPortfolio" />
    it now seems to work.
    Unfortunately blog post page still doesn't work - but hey, maybe I find that as well...
    Best, Simeon
