  • Hafiz 12 posts 84 karma points
    Sep 15, 2017 @ 15:25
    Hafiz
    Umbraco umazel with PureLive mode
    Hi, is it possible to run Umazel Starter Kit with ModelsBuilder mode set to PureLive?
    Sep 17, 2017 @ 22:10
    Alex Skrypnyk
    Hi Hafiz
    Yes, it's possible, Umazel starter kit should work with all Model Builder settings
    Alex
    Sep 19, 2017 @ 08:10
    Hafiz
    Sorry, I forgot to mention that I got an error (when viewing the page) when I change the model to PureLive.
    Sep 19, 2017 @ 08:12
    Alex Skrypnyk
    Hi Hafiz
    Did you push /bin/Umbraco.Web.PublishedContentModels.dll file to Umbraco cloud?
    Please, remove it if you run with PureLive setting.
    Alex
    Sep 19, 2017 @ 08:28
    Hafiz
    Nope, this is in my localhost. Sometimes I also got this error
    Maybe you can try to simulate my condition by installing a fresh copy of Umbraco and install Umazel Starter Kit from the Package. Lastly, change the mode from Dll to PureLive and try to view the Umazel page.
    Sep 19, 2017 @ 08:33
    Alex Skrypnyk
    Do you have " /bin/Umbraco.Web.PublishedContentModels.dll " locally?
    Sep 19, 2017 @ 08:51
    Hafiz
    Yup but when I deleted it. Got another error
    Sep 19, 2017 @ 08:55
    Hafiz
    Yup. When I delete it. Got another error
    Sep 19, 2017 @ 09:12
    Alex Skrypnyk
    Are you sure that local IIS supports PureLive mode?
    It looks like you have to use Dll mode.
    Alex
    Sep 19, 2017 @ 09:39
    Hafiz
    Yup because I can use the PureLive mode when using FastTrack (Merchello Starter Kit). Actually my main objective is to install two Starter Kits that is Umazel and FastTrack Starter Kit. When I use Dll mode, the Umazel works but the Merchello did not. When I use PureLive mode, it's the other way around. Both errors are about the ModelsBuilder, I have tried to use Dll mode on the FastTrack and Regenerate the Models in the backoffice but failed.
    Sep 20, 2017 @ 12:31
    Hafiz
    Help please...
    Sep 20, 2017 @ 13:26
    Alex Skrypnyk
    Hi Hafiz
    Alex
    Sep 20, 2017 @ 13:31
    Hafiz
    Oh bummer. I have to look for another Starter Kit then, too bad I really like Umazel. Anyway, thanks for your help Alex
    Sep 20, 2017 @ 13:39
    Alex Skrypnyk
    You are welcome, Hafiz.
    What starterkit did you choose?
    Alex
    Sep 20, 2017 @ 13:46
    Hafiz
    Still looking. Can you recommend me which CMS Starter Kit (free or paid version) to choose that's compatible with Merchello FastTrack Starter Kit?
    Sep 20, 2017 @ 13:50
    Alex Skrypnyk
    I don't know, I know that "The Starter Kit" is working with latest Umbraco perfectly -
    https://our.umbraco.org/projects/starter-kits/the-starter-kit/
    Sep 20, 2017 @ 14:05
    Hafiz
    I think I'm gonna buy one in uSkinned since it's Contents Nodes are almost the same structure as Umazel. "The Starter Kit" is good but the structure is very basic. Thanks again
    Sep 20, 2017 @ 15:27
    Alex Skrypnyk
    Have a great evening!
  • Marc Love (uSkinned.net) 447 posts 1790 karma points MVP
    Sep 20, 2017 @ 15:01
    Hi Hafiz,
    If you have any questions regarding uSkinned please contact us via:
    https://uskinned.net/contact/
    and we will be happy to answer your queries.
    Marc
  • Francis Benyah 35 posts 112 karma points
    Dec 22, 2020 @ 22:38
    Francis Benyah
    So this is an old post but I got this working on Umbraco 8.9.1 with any of the models builder modes as Alex mentioned.
    After installing the starter kit just make sure you have the following settings in the app settings section you web.config
    <add key="Umbraco.Core.LocalTempStorage" value="EnvironmentTemp" />
    <add key="Umbraco.Examine.LuceneDirectoryFactory" value="Examine.LuceneEngine.Directories.SyncTempEnvDirectoryFactory, Examine" />
    Clean and rebuild the solution.
    Ensure you delete everything in the TEMP folder under AppData otherwise you might just get some sql lock request exceptions
    If you are on azure sql database then you need to include this as well in app settings
    <add key="Umbraco.Core.MainDom.Lock" value="SqlMainDomLock" />
    Then you should be good
