  • Rico 3 posts 23 karma points
    Nov 29, 2017 @ 07:52
    Rico
    Internal links not working or targeting self in version 7.6 / 7.7
    Greetings! Firstly, thanks for your great starter kit. Really good for getting up and running quickly, nice work! I've only just started using the starter kit and when I set internal links they don't got to the other content pages. The top menu works correctly but the link buttons just return to the top of the home page. I've looked in the database and it does not look like the data for the internal links is being added? Any help would be appriciated. Thanks!
    Dec 27, 2017 @ 12:08
    Alex Skrypnyk
    Hi Rico
    Welcome to our forum
    Can you show me how did you render buttons? How are they looking in the backend?
    Alex
    Dec 28, 2017 @ 11:41
    Rico
    Hey Alex,
    This is on the default button from the template. It's when I published the Link Buttons in the Homepage Assets? The button renders when published but the re is no target.
    Many thanks.
    Rico
  • Andrew Bright 84 posts 244 karma points
    Sep 18, 2018 @ 10:08
    Andrew Bright
    I had this issue also and tried to fix with RJP multi Url picker but had no luck. essentially whats happening is the DLinkButton class is being used to obtain a link item which has no idea what a content picker or RJP Url are so I had to update the external link with the required internal link to get round this.
