Is it possible to have the navigation start from a node id instead of a level.
I have a site where i need a persistent menu on all pages, that always renders the subpages of the node with id 1338...
Is that possible? if yes, how?
Site version is 4.0.4.2
Can't you use the parameter forceNode for that?
/Dirk
Absolutely :). Thanks Dirk.
Always wondered what that was for. Works like a charm
starting the menu from a node id instead of level
/Dirk
