  • Maarten Boer 61 posts 82 karma points
    Nov 07, 2010 @ 11:26
    Maarten Boer
    placement of the vertical menu (CSS)
    This package is ver cool. It's exactly what i was looking for.
    Simple UL and IL in CSS let's me configure the output on screen as i want, but the (vertical) CSS with menu gives me the following problem:
    Im placing the menu in a DIV with a gray background so you can see what i mean.
    I've tried everything but i just can't seem to remove or reduce the the space marked with the red arrows.
    Any Idea??
    Maarten
  • Chris Koiak 700 posts 2626 karma points
    Nov 07, 2010 @ 11:47
    Chris Koiak
    Hi Maarten,
    Have you tried using Firebug (https://addons.mozilla.org/en-US/firefox/addon/1843/) in Firefox to help debug this?
    If you 'Inspect' the element in firebug you will see where this space is coming from.
    Chris
    Nov 07, 2010 @ 15:32
    Maarten Boer
    Ok... this show a lot...still can't figure out a solution.
    I have installed the Package [COG] flexible menu. This comes with a macro and a stylesheet
    This is what i got and altered in CSS
    /*VERTICAL NAV*/
    .vertical
        width:144px;
        line-height:1.4em;
        padding-bottom:20px;
        margin:0;
        padding:0;
        text-align:left;
    .vertical ul
        width:144px;
        margin:0px;
        padding-left:0px;
        list-style:none;
        text-align:left;
    .vertical li
        width:144px;
        margin:0px;
        padding-left:0px;
        font-weight:normal;
        color:#9a8b86;
        list-style:none;
        text-align:left;
    /* STANDAARD ALGEMENE OPMAAK */
    .vertical li a
        width:80px;
        font:Arial, Helvetica, sans-serif;
        font-size:14px;
        margin-left:0px;
        padding-left:0px;
        /*display:block;*/
        list-style:none;
        /*padding:3px 3px 3px 5px;*/
        text-decoration:none;
        color:#9a8b86;
    .vertical li a:hover
        /* border-left:5px solid #4dB0aa; */
        color: #d6d800;
        background: url("/scripts/dot.png") left center no-repeat;
    .vertical li a.branch
        /*border-left:5px solid #ccc;*/
        color:#9a8b86;
    .vertical li a.branch:hover
        /*border-left:5px solid #4dB0aa;*/
        color: #d6d800;
    .vertical li a.selected
        /*color: #d6d800;*/
        color:#9a8b86;
    .vertical.lv1 li a {
        font-size:16px;
        padding:3px 3px 3px 0px;
    .vertical .lv2 li a {
        font-size:10px;
        padding:3px 3px 3px 20px;
        border-bottom:1px solid #d6d800;
    Maarten
    Nov 07, 2010 @ 21:20
    Chris Koiak
    Maarten,
    Most browsers have a default style that they apply to some elements, the browser you are using is applying left padding to the navigation ul.
    Try using something like YUI Reset (http://developer.yahoo.com/yui/reset/) to remove all the browser independent styling first and then start to write your own styles.
    Add the following to your master page
    <link rel="stylesheet" type="text/css" href="http://yui.yahooapis.com/2.8.2r1/build/reset/reset-min.css">
    Nov 07, 2010 @ 23:15
    Maarten Boer
    Ok, thanks Will try this first thing tomorrow and Will keep you posted on my progress. Maarten
    Nov 08, 2010 @ 07:57
    Maarten Boer
    Chris,
    You are my hero :)
    I used a part of the reset CSS, UL and LI and included them in my stylesheet....space is gone...
    Maarten
