  • Phil Young 19 posts 39 karma points
    Jan 24, 2011 @ 12:51
    Phil Young
    4.6 compatibility?
    Hi, are you planning to produce a version that is compatible with 4.6? Or failing that, Is there a quick fix I can do that will allow it to work in 4.6..?
    Many thanks, Phil
    Jan 24, 2011 @ 18:56
    Hi Phil
    Have you experienced any problems using this package on a 4.6 installation? On the project page it states that this package is now working with 4.5 so I really do think that it should also be working with 4.6 :-)
    http://our.umbraco.org/projects/website-utilities/cogworks-flexible-navigation
    Give it a go if you haven't done so already.
  • Tim 225 posts 690 karma points
    Feb 24, 2011 @ 11:53
    Tim
    As Jan says there is a 4.5+ compatible version of this package. However by default it was set to download the 4.0+ version. I have now updated the project to download the 4.5+ compatilbe verion by deault.
    If you have any furtehr problems please post them up and I'll see if I can work out what the issue is.
    Tim
