Can't see it in the package is there any ordering or max elements so that the nav can be controlled a bit more?
Hi Steve,
How about adding it yourself, should be quite simple. Make sure to do the ordering before getting max elements
<xsl:sort select="field" type="type" order="ascending|descending" />
/Dirk
Thanks for the fast respone.
Max Elements??
C'mon Steve, LMGTFY... need to use the position() xslt function...
<xsl:for-each select="$yourNodeSet"><xsl:if test="position() <= $yourMaxElements"><!-- process element --></xsl:if></xsl:for-each>
Question if were are using this for two navigations both page and site how do we appliy two separate css styles per type?
Top Navigation Ordering
Hi Steve,
/Dirk
Max Elements??
/Dirk
