I am using the Cogworks Flexnav package on a site under development.
So far I have got Main Navigation and sub navigation working, but I am looking to have sub navigation pages from my home page, has anyone managed to do a site like this.
Me being a total new guy to Umbraco I have no idea were to start.
I would suggest posting a screenshot of your content tree so we can see your site structure, then it might be easier to understand what you are trying to do.
here are a couple of grabs, the first is the content tree of my site.
Next is a grab of my site, showing where I would like the navigation to go.
My site is pretty simple for now, I have a Homepage doctype and a contentpage doctype. all items at the same level as news are contentpage. so looking to split these items as sub pages if poss.
Can't seem to get that to return anything, so going to have a play over the weekend extending the main XSLT to include a bool value of isSubPage so that if isSubPage = true then page will not appear on main nav but will on subnav.
Sub Navigation on Home Page Node
Hi Ian,
Welcome to the forum!
Cheers
Rich
Hi Rich,
Thanks for your speed response :)
Cheers :)
Hey Ian,
The easiest way is to add an xslt file (and a new macro) with this code and replace 1090 with the node id of your 'news' node
<ul>
<xsl:for-each select="umbraco.library:GetXmlNodeById(1090)/* [@isDoc and string(umbracoNaviHide) != '1']">
<li>
</a>
</li>
</xsl:for-each>
</ul>
There are nicer ways of doing this (not relying on hard coding the id) but this should get you started.
Rich
<ul> <xsl:for-each select="umbraco.library:GetXmlNodeById($source)/* [@isDoc and string(umbracoNaviHide) != '1']"> <li> <a href="{umbraco.library:NiceUrl(@id)}"> <xsl:value-of select="@nodeName"/> </a> </li> </xsl:for-each> </ul>Hi Rich,
Have had to change task for now, but will give this a go a bit later on and give some feedback.
Ian
Hi Rich,
