  • Profiterole 232 posts 264 karma points
    Feb 28, 2012 @ 17:39
    Profiterole
    active class for current node only
    Hi, I don't know what I'm doing wrong, but I'd like be able to add a css class to the current node only, even if there's children or not.
    <umbraco:Macro startingLevel="1" recurse="1" selectBranches="0" maxMenuDepth="10" ulBaseClass="" branchClass="" selectedClass="hilight" forceNode="" expandChildren="0" forceHome="0" securityTrimming="1" Alias="[COG]Navigation" runat="server"></umbraco:Macro>
    So, I put 0 on selectBranches because I don't want to apply the branchClass class to the parents.
    The only class I need is to selectedClass. So I put my css class there. (hilight).
    Nevertheless, all the children of the selected node are hilighted. How can I only hilight the current node?
    Hope I'm clear!
    Thank you in advance!
  • Tim 225 posts 690 karma points
    Feb 29, 2012 @ 12:27
    Tim
    I'll take a look. Sounds like it may be a bug.
    Are you using the XSLT version or the Razor version?
    Kindest Regards
    Tim
    Feb 29, 2012 @ 15:01
    Profiterole
    Hi Tim, I'm using xslt version on umbraco 4.7.1
