Seems nice,
Have not tried it yet but it would be nice to have additional classes for the first and last item.
Ron
If umbraco doesn't have that; it should: +1
How do you mean? If listing items with xslt you just use the position() and count() functions to determine your position in an iteration.....
As Darren says, it's a simple thing to do in xslt using the position() and last() functions. I prefer last() but you could certainly use count() if you prefer.
The basic idea would be something like this...
<ul><xsl:for-each select="_something_here_"> <li> <xsl:choose> <xsl:when test="position() = 1"> <xsl:attribute name="class">first</xsl:attribute> </xsl:when> <xsl:when test="position() = last()"> <xsl:attribute name="class">last</xsl:attribute> </xsl:when> </xsl:choose> <xsl:value-of select="@nodeName" /> </li></xsl:for-each></ul>
The output for a loop of four items would be something like this...
<ul> <li class="first">item 1</li> <li>item 2</li> <li>item 3</li> <li class="last">item 4</li></ul>
cheers,doug.
Cool -- thanks for the tip -- just another square-peg php-approach to this elegant solution. I retract my +1.
Classes for first and last item
Seems nice,
Ron
cheers,
doug.
