Hi, I've got exactly the same problem as René. It would be really great if someone (from Cogworks?) could help us with this critical problem. Thanks /Jan
I have tryed to uninstalle Cog Navigation and install again.
Here is the information from the CogWorks Navigetion
Package name Cogworks - Flexible Navigation
Package version 1.0
Author Tim Saunders
Package repository Umbraco package Repository
Package readme
This is the Umbraco 4.5+ version.
it contains support for the new 4.5 schema.
I noticed above that you had startingLevel to zero — that will not render any menus, since there is no level zero node in Umbraco (<root> is level="-1" and top-level nodes are at level="1")
I'm plowing through the XSLT to see if I can find anything that would cause the problems others are having here...
Now the navigation is rendered, so there is som troubles with umbraco and getting the data from the macro.
<!--This sets the level that the nav starts at and tells us if we should recurse through child elements-->
<xsl:variable name="startDepth" select="1" />
<xsl:variable name="recurse" select="1" />
<xsl:variable name="selectBranches" select="1"></xsl:variable>
<xsl:variable name="maxMenuDepth" select="99"></xsl:variable>
<xsl:variable name="forceNode" select="0"></xsl:variable>
<xsl:variable name="walkChildren" select="1"></xsl:variable>
<xsl:variable name="forceHome" select="1"></xsl:variable>
<xsl:variable name="securityTrimming" select="1"></xsl:variable>
<!--Alternate page title variable in here-->
<!--Styles for the navigation-->
<xsl:variable name="ulBaseClass" select="0"></xsl:variable>
<xsl:variable name="branchClass" select="0"></xsl:variable>
<xsl:variable name="selectedClass" select="0"></xsl:variable>
<p> ---- MENU COG START ---- </p>
<ul class="0 lv1">
<li class="0 hasChildren"><a href="/" class="0">page1</a></li>
<li class="hasChildren"><a href="/1.aspx">1</a><ul class="lv2">
<li class="hasChildren"><a href="/1/11.aspx">11</a><ul class="lv3">
<li><a href="/1/11/111.aspx">111</a></li>
<li><a href="/1/11/112.aspx">112</a></li>
</ul>
</li>
<li><a href="/1/12.aspx">12</a></li>
<li><a href="/1/13.aspx">13</a></li>
</ul>
</li>
<li><a href="/2.aspx">2</a></li>
<li><a href="/3.aspx">3</a></li>
<li><a href="/4.aspx">4</a></li>
<li><a href="/5.aspx">5</a></li>
</ul>
<p> ---- MENU COG END ---- </p>
<p> ---- MENU LEvel 1 STANDARD START ---- </p>
<ul><li><a href="/1.aspx">1</a></li><li><a href="/2.aspx">2</a></li><li><a href="/3.aspx">3</a></li><li><a href="/4.aspx">4</a></li><li><a href="/5.aspx">5</a></li></ul>
<p> ---- MENU STANDARD END ---- </p>
<p> ---- MENU level 2 STANDARD START ---- </p>
<ul />
Page 1
A
I had this same issue and was able to get the menu to work by changing the [COG]Navigation.xslt file:
Before:
<xsl:choose> <xsl:when test="$forceNode">
After (this works for me):
<xsl:choose> <xsl:when test="$forceNode > 0">
Seems the simple first test to check for a value is always returning true for me. When I tested to make sure it was a value above 0 (which it would need to be in order to be an actual node) it worked like it was before I upgraded to version 6.1.6.
OK, that really starts looking as if there's been a change in the way the <macro> document gets created from the parameters. Especially it seems that unspecified parameters are converted into either zero or some kind of 'null' string... (Otherwise, the simple test="$forceNode" wouldn't return true())
Could you (René and Phill) try the age old copy-of trick to get some data for us? That is, setup the macro as you usually do with some parameters not specified (e.g. leave the forceNode - aka "Selected Page" - param empty), then do this inside the root template (<xsl:template match="/">) before everything else:
Thanks - I've been debugging a little myself, and I've tried this on an older 4.11.x version - the problem is that empty parameters are now always present in the macro XML - whereas, in the older versions, they only ocurred if they had an actual value - before, if you had an empty string, it wouldn't add the
So the way we usually have been checking this in XSLT was to just look for the node - now, it seems that the XSLT needs to be updated to make sure there's an id in there... the test="$forceNode > 0" as Phill suggested will do that - best option would probably be to refactor some of the code to do all the conversions in the variables section to make the variables act like they did before, but depending on how they're used throughout the code that needs to be tested a little more.
Cogworks menu doesnt render
I have installed the pakcage and used as described in Umbraco 6.1.3.But my menu deosnt render.
Here is my code in masterpage
<!-- menu -->
<div id="navcontainer">
<umbraco:Macro startingLevel="2" recurse="1" selectBranches="1" maxMenuDepth="999" ulBaseClass="vertical" branchClass="branch" selectedClass="selected" securityTrimming="1" Alias="[COG]Navigation" runat="server"></umbraco:Macro>
<!-- end menu -->
Nothing is rendering and output is this
<div id="navcontainer-default">
I have the same problem in Umrbraco v6.1.3. Does someone know if there is a solution for this?
thanks
Same in 6.1.6... Any solution?
Hi I´m running Umbraco v6.1.6 (Assembly version: 1.0.5021.24867) and i can´t get the Cogworks - Flexible Navigation to render.
Here is the debug result, it looks like it should work.
Any ideeas..
René
Its really strange since its pure xslt, and as far as i know there hasn't been any change to xslt in V6?!?!?!
I have been looking at this and it is a bit strange.
When i Visualize XSLT - Cog Navigation it works
Any ideas???
Rene
Hi again
It is a bit strange. Here is the output from the Cog Navigation, I do not know where the div come from.
Here is the markup for the macro
Any suggestions?
Kindly René
Hi again
Now i have tryed on a new install of Umbraco 6.1.6 - With the same result.
Any ideas would be great.
A simpel demo with 3 menues, all XSLT
The content three
The XSLT Files
This is the source view off the simple site (Nothing for Cog navigation) - The other 2 XSLT Navigation is rendered fine
Any Ideas
Have a nice sunday
René
Hi René,
startingLevelto zero — that will not render any menus, since there is no level zero node in Umbraco (<root>is level="-1" and top-level nodes are at level="1")I'm plowing through the XSLT to see if I can find anything that would cause the problems others are having here...
/Chriztian
Hi Chriztian
I have tested with level 1 and -1, nothing renderes in the COG Menu
Here is the out put with level 1 (Nothing rendere)
<umbraco:Macro startingLevel="1" recurse="1" selectBranches="1" maxMenuDepth="99" ulBaseClass="" branchClass="" selectedClass="" forceNode="" expandChildren="1" forceHome="1" securityTrimming="1" Alias="[COG]Navigation" runat="server"> </umbraco:Macro>Here is the output with level -1
<umbraco:Macro startingLevel="-1" recurse="1" selectBranches="1" maxMenuDepth="99" ulBaseClass="" branchClass="" selectedClass="" forceNode="" expandChildren="1" forceHome="1" securityTrimming="1" Alias="[COG]Navigation" runat="server"> </umbraco:Macro>Hi
Is there anything new on this one.
Chritzian, could you produce the error?
René
Hi Rene
Have you tried setting the variables in the xslt manually to see if it works?
Replace macro/startingLevel with 2, macro/recurse with 1 etc.
Cheers
Rob
Hi Rob
I have tried and it works.
<p> ---- MENU COG START ---- </p> <ul class="0 lv1"> <li class="0 hasChildren"><a href="/" class="0">page1</a></li> <li class="hasChildren"><a href="/1.aspx">1</a><ul class="lv2"> <li class="hasChildren"><a href="/1/11.aspx">11</a><ul class="lv3"> <li><a href="/1/11/111.aspx">111</a></li> <li><a href="/1/11/112.aspx">112</a></li> </ul> </li> <li><a href="/1/12.aspx">12</a></li> <li><a href="/1/13.aspx">13</a></li> </ul> </li> <li><a href="/2.aspx">2</a></li> <li><a href="/3.aspx">3</a></li> <li><a href="/4.aspx">4</a></li> <li><a href="/5.aspx">5</a></li> </ul> <p> ---- MENU COG END ---- </p> <p> ---- MENU LEvel 1 STANDARD START ---- </p> <ul><li><a href="/1.aspx">1</a></li><li><a href="/2.aspx">2</a></li><li><a href="/3.aspx">3</a></li><li><a href="/4.aspx">4</a></li><li><a href="/5.aspx">5</a></li></ul> <p> ---- MENU STANDARD END ---- </p> <p> ---- MENU level 2 STANDARD START ---- </p> <ul /> <p> ---- MENU STANDARD END ---- </p> Page 1 ARene
Hi there,
Before:
<xsl:choose>
<xsl:choose>
phill
<macro>document gets created from the parameters. Especially it seems that unspecified parameters are converted into either zero or some kind of 'null' string... (Otherwise, the simpletest="$forceNode"wouldn't returntrue())Could you (René and Phill) try the age old copy-of trick to get some data for us? That is, setup the macro as you usually do with some parameters not specified (e.g. leave the forceNode - aka "Selected Page" - param empty), then do this inside the root template (
<xsl:template match="/">) before everything else:I'm very curious as to see what gets in there for the missing parameters...
/Chriztian
UPDATE: Added UI name of the forceNode param
Hi Christzian
Here is the output.
This is the settings
<umbraco:Macro startingLevel="1" recurse="1" selectBranches="1" maxMenuDepth="99" ulBaseClass="" branchClass="" selectedClass="" forceNode="" expandChildren="1" forceHome="" securityTrimming="1" Alias="[COG]Navigation" runat="server"> </umbraco:Macro>Hi René,
test="$forceNode > 0"as Phill suggested will do that - best option would probably be to refactor some of the code to do all the conversions in the variables section to make the variables act like they did before, but depending on how they're used throughout the code that needs to be tested a little more./Chrizitan
