  • Tim 1193 posts 2675 karma points MVP 4x c-trib
    Nov 17, 2009 @ 13:50
    Tim
    Empty class tags
    Hi Tim,
    Nice macro! I noticed that it generates a lot of empty class tags and class tags with extra trailing spaces though. If you dump the class string into a variable and then check if its there before adding the classes, you can eliminate the empty tags (and use the normalise-space function to kill the trailing spaces). Here's the code I used:
    <xsl:variable name="itemClass">
    <xsl:if test="$isSelected = 1"><xsl:value-of select="concat($selectedClass,' ')"/></xsl:if>
      <xsl:if test="$isSelectedBranch = 1"><xsl:value-of select="concat($branchClass,' ')"/></xsl:if>
      <xsl:if test="$hasChildren = 1"><xsl:value-of select="'hasChildren '"/></xsl:if>
    </xsl:variable>
    <xsl:if test="string-length($itemClass) > 0">
    <xsl:attribute name="class">
      <xsl:value-of select="normalize-space($itemClass)"/>
      </xsl:attribute>
    </xsl:if>
    It doesn't seem to impact the performance from the tests I've run, and you get cleaner html output.
  • Tim 225 posts 690 karma points
    Nov 19, 2009 @ 13:49
    Tim
    Hi Tim,
    Thanks for the code, this was definately on my list of things to tidy up. I'll have a look at implementing your approach in the next release.
    Tim
  • Isaac Levin 22 posts 42 karma points
    May 10, 2010 @ 16:52
    Isaac Levin
    Tim,
    Can you go into a little more detail what you are doing here? I would like to implement this to what I am currently working on. Thanks.
