It looks like this suggestion was put into the current code, but we still get empty ul if there are docs that have umbracoNaviHide set, so I changed the test to this:
<xsl:if test="$parentNode/*[@isDoc][string(umbracoNaviHide) != '1'] or ($calculatedMenuDepth = 1 and $forceHome)">
Thanks Claire! This should really be included. For me it messed up a lot more than just the semantics. The "isBranch" variable also needs this condition (if you use it). Like this:
Don't render empty ul
What
Why
Solution
Proposed solution:
surround ul element with conditional
<xsl:if test="$parentNode/node or $calculatedMednuDepth = 1 and $forceHome">
<ul>
Means:
Only render ul-menu if there are children ;
with exception if forceHome is selected and it's the 1'st level (the actual home link)
<xsl:variable name="isBranch"> <xsl:choose> <xsl:when test="$currentPage/ancestor-or-self::*[@isDoc][@id = $currentNodeID]/child::*[@isDoc][string(umbracoNaviHide) != '1'] and string(count(descendant::umbracoNaviHide[text() = '0'])) != '0'">1</xsl:when> </xsl:choose> </xsl:variable>is working on a reply...
