I've installed the RestContourPreview package on 4.5.2 and I'm getting a HTTP 405 error - method not allowed when I try to submit the example form.
The restExtensions.config & xsltExtensions.config have been updated.
Any ideas?
Hi Neil
Where do you experience the problem? Is it a local installation or is the solution hosted somewhere? I think there might be an issue with the setup in IIS, which needs to allow the POST method of your form.
Hi Jan,
It is a local install running iis 5.1
Could this walk-through perhaps be the solution to your problem? http://www.somacon.com/p126.php
Adding the script map for .html extension hasn't helped.
In this step
Click the "Browse..." button, choose "Dynamic Link Libraries *.dll" from the "Files of Type" dropdown, and select c:\WINDOWS\System32\inetsrv\asp.dll.
Could it might be you need to choose a aspx.dll if such one exists?
Unfortunately I don't have access to a IIS 5.1 so I'm fumbling a bit here I must admit.
Following http://www.somacon.com/p126.php I created a test.html and this will POST without any errors.
restcontour.aspx on the other hand still
POST http://localhost/base/submitContourForm/CreateRecord/405 Method not allowed 2ms
A few sites have suggested urlrewriting rules, however i've not set any rules in the urlrewriting.config.
I've even tried adding this url to umbracoReservedUrls - to no avail.
Neil
HTTP 405 error - method not allowed when submitting form
Any ideas?
Hi Neil
Hi Jan,
Hi Neil
Hi Jan,
Hi Neil
In this step
Hi Jan,
Neil
