  • Morten Jensen 2 posts 22 karma points
    Nov 21, 2011 @ 15:29
    Morten Jensen
    Missing script?
    I notice that i did not get the same error as you, and even thogh ive set the guid and done all in vid I cant get it to work.
    What am i doing wrong, can you help me?
    This is the error i get.
    Error occured
    System.Xml.Xsl.XslTransformException: Cannot find a script or an extension object associated with namespace 'urn:cultiv.restcontour'.
    at System.Xml.Xsl.Runtime.XmlQueryContext.InvokeXsltLateBoundFunction(String name, String namespaceUri, IList`1[] args)
    at (XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at Root(XmlQueryRuntime {urn:schemas-microsoft-com:xslt-debug}runtime)
    at System.Xml.Xsl.XmlILCommand.Execute(Object defaultDocument, XmlResolver dataSources, XsltArgumentList argumentList, XmlWriter writer)
    at System.Xml.Xsl.XslCompiledTransform.Transform(IXPathNavigable input, XsltArgumentList arguments, TextWriter results)
    at umbraco.presentation.webservices.codeEditorSave.SaveXslt(String fileName, String oldName, String fileContents, Boolean ignoreDebugging)
    Best Regards
    Morten Jensen
    Nov 21, 2011 @ 22:35
    Hi Morten
    Is this an error yout get on all XSLT files you're trying to view inside of Umbraco? Or is it only happening to a specific file? If it's happening to a specific file please post the XSLT code in here - then it'll be much more easy to figure out what might cause this :)
    I'm thinking that you might have missed to include the namespace in the XSLT file?
    Nov 22, 2011 @ 09:13
    Morten Jensen
    I only get this error in this XSLT file..
    This is my code.
    <!DOCTYPE xsl:stylesheet [
      <!ENTITY nbsp "&#x00A0;">
    <xsl:stylesheet
      version="1.0"
      xmlns:umbraco.library="urn:umbraco.library" xmlns:Exslt.ExsltCommon="urn:Exslt.ExsltCommon" xmlns:Exslt.ExsltDatesAndTimes="urn:Exslt.ExsltDatesAndTimes" xmlns:Exslt.ExsltMath="urn:Exslt.ExsltMath" xmlns:Exslt.ExsltRegularExpressions="urn:Exslt.ExsltRegularExpressions" xmlns:Exslt.ExsltStrings="urn:Exslt.ExsltStrings" xmlns:Exslt.ExsltSets="urn:Exslt.ExsltSets" xmlns:rc="urn:cultiv.restcontour"
      exclude-result-prefixes="msxml umbraco.library Exslt.ExsltCommon Exslt.ExsltDatesAndTimes Exslt.ExsltMath Exslt.ExsltRegularExpressions Exslt.ExsltStrings Exslt.ExsltSets rc ">
      <xsl:output method="xml" omit-xml-declaration="yes" indent="yes"/>
      <xsl:template match="/">
        <style>
                .hide { display: none; }
                ul, li { list-style-type: none; }
        </style>
        <xsl:variable name="setFormGuid" select="rc:SetContourGuid('c5308a8c-49dd-4b3a-a5e2-a0eb0ad28ead')"/>
        <xsl:variable name="formGuid" select="rc:GetContourGuid('c5308a8c-49dd-4b3a-a5e2-a0eb0ad28ead')"/>
        <form action="" method="post" id="form-{$formGuid}" name="ApplyForpartnership">
        <div style="background: url(/media/13440/applypartner222.png) no-repeat; width:225px; height:298px;">
        <div style="padding-left:29px; padding-top:82px;">
          <ul class="formArea">
            <li>
              <input type="text" name="Navn"/>
            </li>
            <li>
              <input type="text" name="Email"/>
            </li>
            <li>
              <textarea name="Ansoegning">
                <xsl:text> </xsl:text>
              </textarea>
            </li>
            <li class="send-button">
              <input type="submit" value="Send" class="button" />
            </li>
            <li class="errorList">
              <ul class="errorList">
                <xsl:comment/>
              </ul>
            </li>
          </ul>
          <div class="formLoading hide">
            <h2>Processing</h2>
            <h4>The form is being sent</h4>
          <div class="formPosted hide">
            <h2>Thanks</h2>
            <h4>We've successfully recieved the form, thanks!</h4>
        </form>
          <xsl:text>jQuery(document).ready(function () {</xsl:text>
          <xsl:value-of select="rc:BuildForm()"/>
          <xsl:text>});</xsl:text>
        </script>
      </xsl:template>
    </xsl:stylesheet>
