I needed to use RestContour to submit a form with a checkboxlist which can have multiple values, which wasn't working quite right, because RestContour out of the box will only submit a single string per record field. So at line 129 in SubmitContourForm.cs I added:
if (recordField.Field.FieldType is Umbraco.Forms.Core.Providers.FieldTypes.CheckBoxList)
recordField.Values = new List<Object>((recordField.Values[0] as String).Split(','));
And now I can submit comma-separated lists of checkbox GUIDs which will be interpreted correctly. Maybe it will be useful for someone else.
Patch to allow CheckBoxLists to work rightly
if (recordField.Field.FieldType is Umbraco.Forms.Core.Providers.FieldTypes.CheckBoxList) recordField.Values = new List<Object>((recordField.Values[0] as String).Split(','));And now I can submit comma-separated lists of checkbox GUIDs which will be interpreted correctly. Maybe it will be useful for someone else.
Evan Harper
