Index was out of range. Must be non-negative and less than the size of the collection.
When I attempt to view a node with the Template (updated with the current node ID as the source, and the child doctype alias), I see this error:
Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
Description: An unhandled exception occurred during
the execution of the current web request. Please review the stack trace
for more information about the error and where it originated in the
code.
Exception Details: System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
Source Error:
An unhandled exception was generated during the execution of the current
web request. Information regarding the origin and location of the
exception can be identified using the exception stack trace below.
Stack Trace:
[ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index]
System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource) +64
System.ThrowHelper.ThrowArgumentOutOfRangeException() +15
System.Collections.Generic.List`1.get_Item(Int32 index) +7499260
EyeCatchCSVGenerator.EyeCatchCSVGenerator.Page_Load(Object sender, EventArgs e) +970
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.Parameter name: index
Source Error:
Figured it out - doctype alias is case-sensitive and I had an error there in my macro param.
Thanks for a nice package!
