  • mph 44 posts 78 karma points
    Sep 21, 2010 @ 11:38
    mph
    2
    Uninstallation guide for 1.3
    Hi, I do not seem to be able to find the uninstallation documentation, as a service I've pasted the info showed af the install:
    Uninstalling the Gecko Uploadifyd package
    Warning: If you wish to uninstall the package be sure to follow the instructions below in the in the correct order, otherwise you could end up invalidating the folders in the media section.
    1. Go to the Settings section and expand the Media Type folder
    2. Click on Folder, go to the Generic Properties tab and delete the property "Upload Files"
    3. Go to the Tabs tab and delete the Upload tab
    4. Go to the Developer section and delete the Gecko Uploadify data type as well as the macro
    5. Finally, make sure the files listed above are removed from the file system
    /Michael
    Sep 22, 2010 @ 15:59
    dandrayne
    Hi Michael
    Thanks for this - this seems to have been a bit of over-reuse of the installer Noerds excellent multiple file uploader from the past.  I'll make a note of this for the next release.
    Dan
  • Lachlann 344 posts 626 karma points
    Jan 06, 2011 @ 18:21
    Lachlann
    Thanks for the guide,
    For any one who trys to uninstall before reading this (like i just did) you can still follow these steps but before you try and remove the uploader tab from the media folder in the settings section. You may first have to change the datatype form the uploadify one to something else.
    L
  • Kevon K. Hayes 255 posts 281 karma points
    Apr 27, 2012 @ 20:26
    Kevon K. Hayes
    I believe I invalidated my media section... no matter how I link to a file it doesn't show up on the publsihed page... how can I fix this?
