  • Bijesh Tank 192 posts 420 karma points
    May 17, 2012 @ 15:31
    Bijesh Tank
    Using the 'upload' method rather than auto
    I think this is a brilliant package, but is there a way I can use this package to use the uploadify 'upload' method rather than auto?  I've switched the auto property to false and followed the instruction here on the uploadify site (http://www.uploadify.com/documentation/uploadify/upload/) to trigger the upload method on the link.
    When I try it with this script is doesn't seem to do anything, the file sits in the queue and does not get uploaded.
    Bij
  • Emanuel 63 posts 283 karma points
    Jun 19, 2012 @ 10:58
    Emanuel
    Hi Bijesh,
    I presume you changed the "Uploadify.ascx" file and replaced "'auto': true," with "'auto': false,".
    If so, that should be enough to make change you need. If it's not working, that's more down to Uploadify usage, as we didn't change Uploadify.
    Emanuel
