  • wangyjx 4 posts 24 karma points
    Aug 06, 2012 @ 07:08
    wangyjx
    Problem when upload files
       I am using Umbraco 4.7.1.1 and trying to use Gecko Uploadify to upload multi files. After installation, when I try to upload some files in folder, I alwasy get below error no matter what the file size and type is.
    I tried reflector the code, but nothing related can be found.
    Can anyone help me on this? Thanks a lot
  • Emanuel 63 posts 283 karma points
    Aug 06, 2012 @ 10:18
    Emanuel
    Can you check web.config settings and  Windows permissions on the folder containing the umbraco website?
    Emanuel
    Aug 09, 2012 @ 10:08
    wangyjx
    @Emanuel,
     it was indeed the permission problem for the folder containing the umbraco website. Thank you
    Aug 10, 2012 @ 06:23
    wangyjx
    @Emanuel,
       I deployed to another machine, this error occurs again, all permissions are set to the network service and IIS_IUSER.  No idea again.
    Aug 10, 2012 @ 12:01
    Emanuel
    wangyjx, it will be the same problem again.
    Chek your permissions. You might even want to set the folder permissions to "Everyone" and have it cascade down just to really attest that the upload works.
