Great package. Used it several times, but now we're having a major problem getting the macro code to be saved when calling it through the rich text editor. It wasn't an issue in 4.7.0. Started happening with 4.7.1. Did the upgrade to 4.7.2 to see if that would fix it. No luck. I'm at a loss. We really need a fix soon. Any ideas? Thanks!
Update on this post. Noticing different behaviors in different browsers and positioning of elements. Most likely a TinyMCE config error based on other forum posts. Here's what we're getting...
If the macro is the first element in the RTE window, the script is removed after saving/publishing. If the macro is entered after some bit of text, works fine. If working on a PC in IE 9 or Safari, won't work. Seems to work consistently in Chrome.
Macro not saving code through RTE in 4.7.1+
Hi Doug
I know that there has been some problem with Umbraco and TinyMCE - and it sounds like this is one of them. Dont have a solution how to fix it - sorry.
Kind regards
Anders
