  • Peter Cort Larsen 421 posts 1038 karma points
    Apr 20, 2012 @ 09:58
    Peter Cort Larsen
    Copy Document ToRelated On Publish AGAIN
    When i create a new page under 'English', the page is copied to other languages, perfect.
    But when i create a new page under a different language than 'English', the page is only copied to the language itself.
    The new extra page is prefixed with nodename and (1). Not the effect i want. Do anyone wnat this to happen?
    Is it possible to also auto copy pages created under other languages than english, to all languages?
    I tried removing the setting in web.config '<add key="umbracoDefaultUILanguage" value="en" />', but this has no effect.
    Hope you can help!
    Thanks.
    Apr 20, 2012 @ 10:02
    Peter Cort Larsen
    I should mention, that my parent node with the host name added, has a relation to the english parent node
