  • Tigran 4 posts 24 karma points
    Jun 27, 2014 @ 16:09
    Tigran
    The languages are not rendering on Umbraco 7
    Hello
    I am using this package to have multilanguage webpage.
    I have used this package many time with Umbraco 6, and I have no any problems.
    When I have switched to Umbraco 7 and tried to do same for haveing multilanguage webpage the languages are not rendering.
    Seams Macroses are not working.
    I checked metadata macros also, and it is also not rendearing.
    Could You pelase help me, is anybody worked on umbraco 7 with this package.
    Thanks in advance
    Jun 27, 2014 @ 16:58
    Hi Tigran
    I don't think this package is compatible with Umbraco 7 since it was released in 2011 and A LOT has happened with Umbraco and the way Umbraco works under the hood since.
    I must admit I have never used this package before so I'm not fully aware of what it does - But I'm wondering if you could perhaps use the Vorto package instead?
  • Jorge 7 posts 27 karma points
    Jul 15, 2014 @ 18:44
    Jorge
    I have been struggling with the language switcher after upgrading to Umbraco 7. I wrote a simple, quite untidy & very probably newbie xslt just to cover what I need. It does not include functionality of the package of course. Just a simple language switcher for 1-to-1 related pages. I hope it helps others somehow & that the package gets compatible with Umbraco 7.
    So in my case, I have /de and /en folders. All related to each other bidirectional through "Relate to original".
    <xsl:variable name="relations" select="umbraco.library:GetRelatedNodesAsXml($currentPage/@id)//relation"/>
    <xsl:variable name="niceUrl" select="umbraco.library:NiceUrl($currentPage/@id)"/>
    <ul>
        <xsl:for-each select="$relations">
            <xsl:choose>
                <!-- EN -->
                <xsl:when test="contains($niceUrl, '/en/')">
                    <xsl:variable name="url" select="umbraco.library:NiceUrl(@childId)" />
                    <li><strong>EN</strong></li>
                    <xsl:if test="$url != ''">
                        <li><a href="{$url}">DE</a></li>
                    </xsl:if>
                </xsl:when>
                <!-- DE -->
                <xsl:otherwise>
                    <xsl:variable name="url" select="umbraco.library:NiceUrl(@parentId)" />
                        <li><a href="{$url}">EN</a></li>
                    </xsl:if>
                    <li><strong>DE</strong></li>
                </xsl:otherwise>
            </xsl:choose>
        </xsl:for-each>
    </ul>
    Any updates, corrections are more than welcome!
