  • Steve Jones 36 posts 84 karma points
    Oct 06, 2011 @ 13:44
    Steve Jones
    Error in Nivo after upgrading to Umbraco 4.7.1
    Can you asssist??
    Error loading Razor Script NivoSlider.cshtml
    Input string was not in a correct format.
  • AValor 32 posts 56 karma points
    Oct 06, 2011 @ 13:47
    AValor
    Hi, as stated at the project page...
    NOTE: Due to a BUG in Umbraco 4.7.1 the package is not compatible with this version. If you want to use it anyway, you have to download the fixed code: Go to this item in Issue Tracker (http://umbraco.codeplex.com/workitem/30504), download the code, compile the project umbraco.MacroEngines (with Release config) using VS2010 SP1 and override the compiled 'umbraco.MacroEngines.Juno\bin\Release\umbraco.MacroEngines.dll' in your installation.
    If you have problems with this, I could send you the dll compiled.
    Also note that you have to use the version 0.5 of the package
    Oct 06, 2011 @ 13:52
    Steve Jones
    Could you send the dll and could you tell me what implications there may be upgrading from 0.3 to 0.5 of your package, will it wipe out the current slider settings??
    Oct 06, 2011 @ 14:05
    AValor
    I just uploaded a compiled dll in the Source Code section. Use it at your own risk! :)
    The differences between version 0.3 to 0.5 are just bug fix for IE7 and 'compatibility' for Umbraco 4.7.1.
    Oct 06, 2011 @ 15:44
    Steve Jones
    Sorry to be a pain but I cant see it in the Source Code section
    Oct 06, 2011 @ 16:15
    AValor
    In http://our.umbraco.org/projects/website-utilities/nivoslider-for-umbraco, look for the Source Code tab at the bottom
