Now, I changed the design of it quite a bit, but i've noticed a few problems.
1) The Image and the Caption are not in sync. Teal = Slide 1 -- Purple = Slide 2 -- Yellow = Slide 3 if you watch the captions change must faster than images, however the images eventually catch up.
2) I modified the Nivo Media Type to add a "Title" as a textstring. Now in the Macro code I modified it like so.
<div id="@nodes.Name" class="nivoSlider"> @foreach (dynamic img in nodes.Children) { if (img.NodeTypeAlias != "NivoSliderImage") { continue; } System.Text.StringBuilder htmlNode = new System.Text.StringBuilder(); if (img.HasValue("nivoSliderUrl")) { dynamic destNode = new DynamicNode(img.nivoSliderUrl); htmlNode.Append("<a href=\""+destNode.NiceUrl+"\" >"); } htmlNode.Append("<h2>" + img.nivoTitle + "</h2>"); htmlNode.Append("<img src=\""+img.umbracoFile+"\" alt=\""+img.Name+"\""); if (img.HasValue("nivoSliderCaption")) { htmlNode.Append(" title=\"#"+img.Name+"\""); } htmlNode.Append("/>"); if (img.HasValue("nivoSliderUrl")) { htmlNode.Append("</a>"); }
htmlNode.AppendLine(); @Html.Raw(htmlNode.ToString()); } </div> foreach (dynamic img in nodes.Children) { if (img.HasValue("nivoSliderCaption")) { <div id="@img.Name" class="nivo-html-caption"> @Html.Raw(img.nivoSliderCaption) </div> }
If you notice that the Slider Title is not changing as it should (They are labled "Slider #1" "Slider #2" "Slider #3")
I was able to solve #1 problem with the slider images not syncing with the captions. I had 'random' effect selected and I switched to 'fade' or actually any effect but random this problem was resolved.
I am still trying to figure out #2 ... it still will only display the title from the First slide, not refreshing to the next.
Issues with Slider
Hi - sorry for the other post...won't let me delete it !
I implemented Nivo into my 4.7 Umbraco installation at http://regulus.mountaininteractive.ca/
Any help would be much appreciated.
Cheers
