UmbracoPersonalisationGroups.PersonalisationGroupDefinitionController' is not a function
Hi Andy,
I'm getting the following error on a fresh install of 7.2.8 with 0.1.10 whenever I open a Personalisation Group document type. I've flushed Client Dependency and rebuilt a couple of times but no dice. Any ideas?
Error: Argument 'UmbracoPersonalisationGroups.PersonalisationGroupDefinitionController' is not a function, got undefined
at Error (native)
at cb (http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…NZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:7:622)
at xa (http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…NZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:7:695)
at $get (http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…ZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:11:310)
at http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…ZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:9:6382
at n (http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…NZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:4:576)
at k (http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…ZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:9:6247)
at e (http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…ZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:9:4220)
at http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…ZW51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:9:3783
at http://localhost:63746/DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9q…51L0FjdGlvbk5ld1JlbGF0aW9uVHlwZS5qczs&t=Javascript&cdv=1829008451:18:19495(anonymous function) @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:12$get @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:11j.promise.then.i @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14j.promise.then.i @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14j.promise.then.i @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14j.promise.then.i @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14(anonymous function) @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14$get.e.$eval @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14$get.e.$digest @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14$get.e.$apply @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14j @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:14r @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:15v.onreadystatechange @ DependencyHandler.axd?s=L3VtYnJhY28vbGliL2pxdWVyeS9qcXVlcnkubWluLmpzOy91bWJyYWNvL2xpYi9hbmd1bGFyLzE…:16
Cheers!
p.s. Where do you ideally want issues raised? Here or Github?
More info here - looks like things have moved on since I last saw this thread, so might be something I can do now without having to whitelist the domains.
Hi Andy,
7.2.8with0.1.10whenever I open aPersonalisation Groupdocument type. I've flushed Client Dependency and rebuilt a couple of times but no dice. Any ideas?Cheers!
It sounds like this issue - you can read there for details but it's something I couldn't get around when using embedded resources.
Here or GitHub is fine... not getting swamped yet :-)
Thanks, just read through that and figured it. Agreed. Looks like you can work around it now.
