I'm trying to create a way of displaying the results of a user's search on my sites product page. For example if the user searches for t-shirts I'm trying to display the results on the a page with 4-5 rows and X number of columns, and maybe a page number feature at the bottom i.e. with previous 1 2 3 next etc. Each product will have an Image with 2-3 description tages such as name and price etc.
I did post a similar thread where and was suggested to use xslt for this for this effect.
This is my second site to create and my first one using umbraco. I'm planning on having around 200+ products on the site.
My questions are to do something like the above would I be better to store the product images and data in a database and query it to return and display the results? Or would it be easier to use document types? Are there any advantages of either method.
I have only used XSLT to create the site navigation menu and footers so I have little experience with it, so if anybody can suggest which of the above methods would be best and help me get started on the XSLT it would be greatly appreciated.
XSLT help and Advice
I'm trying to create something to this effect
Product Image Product Image Product Image Product Image
Description Description Description Description
Price Price Price Price
Previous 1 2 3 . . 5 Next
One XSLT example I have been looking at was the solution found here: http://our.umbraco.org/forum/developers/xslt/11527-Problem-with-listing-HTLM-strcuture-with-XSLT
I have tried a similar example were I have product and product items, but I'm unsure how to edit the XSLT to get the effect I am looking for.
Steve
